Jason,
I don't know all the specifics, but I believe some of the later versions of
Epicor have some other option besides Service Connect for EDI. It may be
called EDI-Direct, or some similar type name. That may be an option for you
to discuss with your CAM.
Kevin Simon
Elizabeth
Sent: Friday, May 25, 2012 1:46 PM
Subject: [Vantage] Re: SQL Question / Direct Import
At a previous employer we did this through Service Connect (a consultant had
set it up). I don't think that would make your time window though... as I
recall we did about 15k lines in about 4 hours.
It all came to us as a flat text file, and the SC workflow did all the
folding, bending, spindling, and mutilating so the next morning it was all
there.
Ernie Lowell
Diba Industries
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Jason
Kevin Simon
Elizabeth
there.
Ernie Lowell
Diba Industries
>[Non-text portions of this message have been removed]
> We are still not completely satisfied with the length of time that
> Direct Import (EDI) takes to process all of our incoming demand. We
> might consider writing our own solution directly into SQL like we did
> with our previous ERP system. Our goal is to get all of our demand in
> our system (or updated) daily within about a 2 hour window. We currently
> have about 75,000 schedules from our customers. I am currently only able
> to run this on the weekend, and have gotten it down from a 2 day affair
> to about one day, but not going out as far as we really need to. This is
> a huge delta, so I doubt that 700 will get us the rest of the way, but I
> will be testing that over the next few weeks. (I know that daily imports
> seem crazy, but our customers make changes every 4 hours that impact qty
> and dock code.....and we want to use an automated ASN system so we can
> cut our shipping transactions in half.....several hundred daily
> transactions)
> My question is, has anyone written directly to SQL in an Epicor table?
> Does this bypass the business objects that Epicor has if we did it from
> within the application?
> There appears to be 'checksum' kind of fields in each table.....is that
> true, and what impact would this have to my approach I am considering?
> I can download all the demand from the customers portals through
> processing center and to our servers in a total of about 8
> minutes.....writing individual flat files as required by Direct Import.
> We would like to query the necessary data from Epicor and do the
> validations and matching in memory and then write to the tables. I think
> they are taking the approach of strictly processing each one through
> individually.....which is taking an incredible amount of time.
> I need to get this down to within our 2 hour window ( or something close
> to that), but don't want to do anything stupid and end up with data
> corruption either. Any advice would be greatly appreciated if it saves
> me in exploration time.
> Thanks,
> Jason Dearth
> Ferco Aerospace Group
