I Have wrongly deleted AP invoice header details though SQL any solution to recover the data with out restoring the data please help on urgent`…
You should be able to go back in time with your Transaction Log.
If you need a easy to use UI Version just grab the Trial of Apex
What do you have available to you for backup data that will mostly determine the way you’ll be able to do your restoration
