SQL trigger Blank Title 85178
BIG shout out of thanks to Vic for helping me on this one! Thanks Vic!
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Rob Bucek
Sent: Tuesday, November 17, 2009 10:55 AM
Subject: [Vantage] SQL trigger
Since Epicor hasn't been willing at this point to give us access to
process tables such as systask (via BAM or BPM) in order to monitor when
MRP is complete, I want to create an SQL trigger that will monitor the
task status field and when it is equal to complete and the task
description equals Process MRP, to change the CheckBox01 field in a UD
table to True (or 1), so my alert attachment can fire at that time. Any
mavericks out there creating home brewed triggers or stored procedures
in their Epicor SQL database? I could use a helpful nudge to get me
started here....
Unfortunately even in V9 data directives doesn't even allow access to
these either L
Rob Bucek
FAX: (715)284-4084
started here....
these either L
Rob Bucek
FAX: (715)284-4084
Rob,
See attached docs. It's a SQL query that nicely shows the most recent
500 tasks (active, completed and errored).
This is what I was chatting with you about at Perspectives.
I created a SQL view from this query. I hit the view with ASP and watch
the auto-refreshing ASP dashboard in Internet Explorer on one of my
monitors all day to monitor the system. (sample screenshot attached)
What I've done in the past is put an Update trigger on Systask.
If SysTask.TaskDescription = 'Process MRP' and the updated value for the
column Status = 'COMPLETE' then {{do your trigger}}. While MRP is
running TaskDescription will equal "ACTIVE".
Look at my query and screenshot and play with it. Look at some of the
existing triggers that Epicor put in SQL on the tables and you should be
able to piece together the syntax and logic.
Let me know if you need more help.
Vic
Of Rob Bucek
Sent: Tuesday, November 17, 2009 11:55 AM
started here....
these either L
Rob Bucek
FAX: (715)284-4084
Vic, You rock! I do remember (in spite of myself). Except for
attachments though (can't do them on yahoo groups)... could you send
that attachment to me offline?
Rob Bucek
FAX: (715)284-4084
Of Vic Drecchio
Sent: Tuesday, November 17, 2009 11:08 AM
Cc: Rob Bucek
Subject: RE: [Vantage] SQL trigger
Rob,
Vic
Behalf
Of Rob Bucek
started here....
these either L
Rob Bucek
FAX: (715)284-4084
