SSRS can it handle Over(Partition)?
I have this situation: I have a dataset with the following expresion:
Select distinct(COUNT(SheetNum)) as TagPerSheet, row_number() OVER(PARTITION BY SheetNum order by SheetNum) AS RowNumberfrom CCTag_64D776CDBAE5452780C2B7AA33490AA6 as T1 group by SheetNum Order By TagPerSheet Desc.
When I run it like this is SSRS it runs correctly but when I do it as text it doesnt run: =“Select distinct(COUNT(SheetNum)) as TagPerSheet, row_number() OVER(PARTITION BY SheetNum order by SheetNum) AS RowNumberfrom CCTag_64D776CDBAE5452780C2B7AA33490AA6 as T1 group by SheetNum Order By TagPerSheet Desc”
Any explenation for that?
Are you getting a particular error message? Not sure if it’s just a copy/paste error, but it looks like there isn’t a space between “AS RowNumber” and “FROM CCTag…”. I would also double check to make sure that CCTag_GUID temporary table still exists when you’re testing the second expression.
I want back all the lost hours I spent on this idiotic error :sob: … You solved my issue - THANK YOU SO MUCH (BTW, the GUID was still avaialble)
For the record, if the query runs on your version MSSQL Server, it will run on the associated version of SSRS.
I mean, aside from the fact that SSRS hates duplicate column names. Everything else is fair game.
