Dears,
I’m having a problem with an SSRS report of my creation, the report runs fine and all except for one expression I wrote whose behavior changes once the condition is not met.
The name of the column which has the expression is “Acceptance Criteria” and the idea behind it came from a couple of fields in specification attribute, the fields are [“ListValues”, “CmbPassValues”].
The expression does the following it checks whether the attribute in question is of type ComboBox, then if it is CB it matches pass values with the list values, extracts the description of the list values, concatenates all the descriptions with “,” and displays them in the report.
There is a trick as to how all this is done since Report Builder doesn’t have loops in it, this has forced me to use the Code Feature in the Report Properties as displayed below.
I wrote a VB function that takes both lists, breaks them down, and loops through them to extract the description and concatenates them, then to return them as one value, it has been tested in Visual Studio.
Public Function GetAcceptanceCriteria(ByVal PLV As String, ByVal LV As String) As String
Dim AC As String = ""
Dim PLVA = PLV.Split("~")
Dim LVA = LV.Split("~")
For i As Integer = 0 To (PLVA.Length - 1)
For j As Integer = 0 To (LVA.Length - 1)
If PLVA(i) = LVA(j).Split("`")(0) Then
If Len(AC) = 0 Then
AC = AC + LVA(j).Split("`")(1)
Else
AC += ", " + LVA(j).Split("`")(1)
End If
End If
Next
Next
If Len(AC) = 0 Then
AC = "Values were not matched!"
End If
Return AC
End Function
Now the problem is that the expression that I wrote works perfectly as long as the attribute type is ComboBox but when it comes across a record with a type of Numeric it returns “#Error”, I attached a copy of a printed report below.
Report-STBSingleTP (Single Test Point for Stabilit_97737.pdf (273.5 KB)
I don’t know what I’m missing here, it is just a single IIF statement that checks whether the type is CB or not, is there anything I need to know about code feature to solve this problem?
I appreciate any information you could give me.
