I have modified the standard time report RDD to add in the ProjPhase table. I then have it as a separate data source in my SSRS report. I am trying to pull the data from the ProjPhase table based on a conditional statement. I am attempting to use the ProjectID and PhaseID as keys together to get the right value out of the ProjPhase table. Here is what I created:
=iif(InStr(Fields!PhaseIDDescription.Value,"Root Phase")>0,"",
Lookup(First(Fields!PhaseID.Value, "ProjPhase") & First(Fields!ProjectID.Value, "ProjPhase"),
Fields!PhaseID.Value & Fields!ProjectID.Value,
First(Fields!UserMapData.Value, "ProjPhase"),"test"))
However, this gives me the following SSRS error:
System.Web.Services.Protocols.SoapException: The Value expression for textrun ‘Textbox3.Paragraphs[0].TextRuns[0]’ contains an aggregate function in an argument to a Lookup or LookupSet function. Aggregate functions cannot be used for the destination or result Expression parameter of a lookup function.
at Microsoft.ReportingServices.Library.ReportingService2005Impl.SetReportDefinition(String Report, Byte[] Definition, Guid batchId, Warning[]& Warnings)
at Microsoft.ReportingServices.Library.ReportingService2005Impl.SetReportDefinition(String Report, Byte[] Definition, Warning[]& Warnings)
at Microsoft.ReportingServices.Library.ReportingService2010Impl.SetItemDefinition(String ItemPath, Byte[] Definition, String expectedItemTypeName, Property[] Properties, Warning[]& Warnings)
at Microsoft.ReportingServices.WebServer.ReportingService2010.SetItemDefinition(String ItemPath, Byte[] Definition, Property[] Properties, Warning[]& Warnings)
What does it think is an aggregate? I searched the Lookup function and the & is supposed to be the right way to use multiple source fields. Anyone know what I have wrong?
