SSRS Multiple Custom PO Forms Needed
ERP10 - On Prem Install
I need some clarification on Custom Forms. I created a Custom Form for PO for our Standard PO Needs. The next form I need to create is a more specific form that is going to require additional fields. I created and saved the Standard form, tested, all is good. Copied a new form for SSRS, changed the report and added the additional fields to the 2nd form. Tested - it was working. I always go back and make sure that the other forms are still working. After my 2nd form was working the 1st form does not. I noticed that in the directory - reports/CustomReports/PurchaseOrderForm/POForm - it is the same directory for both. I attempted to rename the second form - it doesn’t like it. I tried changing the directory and that doesn’t work.
How can I have several modified forms for PO? I know this is possible. Not sure what I’m doing wrong.
Any help is always appreciated!
Thank you,
EL
** I did not use the Sync Dataset by advice of EPIUsers and a Meme that said it all.
@eleale change the name of the rdl and on the report location then upload that using actions upload.
Another approach would be to make one form and have all of the options hide/show on conditions.
Greg
@gpayne - Thank you - I just tried that and it worked. I have several subreports with that form. I took it one step further and renamed the PurchaseOrderForm directory to PurchaseOrderForm1 - this should address my issue :slight_smile:
Thanks!!!
