SSRS Report Error "RunTask: Value cannot be null."
Did you see the above thread? I was looking through this one…
Per that thread…
It sounds like, even though YOUR BAQ and report doesn’t require parameters, the stock APAging report may have them.
Take a look at the stock APAging .rdl file and see if there are parameters in there. If so, you may need to recreate those.
@jkane may have some other thoughts as he was able to help in the previous example.
I’m thinking if you COPIED the existing APAging report but then reassigned it to your custom RDD… those parameters may come along for the ride.
