I have all of the Tablix’s set up, however, the only one that runs is the first one. The others all return a blank report.
If you want to reply to my work email: cpelowski@lesueurinc.com, perhaps I can throw a few more questions at you tomorrow.
I am really green with SSRS so this step is stopping me also.
1.
Add any grouping and group sorting for how it should appear for `Dept – EmpID```
I’ve been trying to view some you tube videos on SSRS but it seems each one has a different way of doing things and I am getting more confused by the minute.
I am going to shut down for the day (actually working from home as I ended up leaving work with a fever / cough / headache)… ugh … hopefully just a normal Minnesota cold and not some other junk.
Each Tablix has its visibility set differently, by comparing the SortBy field of the BAQReportParameter dataset
Each Tablix has its sort set differently.
Each Tablix has a different color border.
Note that the SortBy value is displayed in the header. If you select a different sort during testing, it will display in the header.
Tablix1 shows when “Dept - EmpID” is selected
Tablix2 shows when “Dept - Last Name” is selected
No Tablix is shown when “Last Name” is selected. Because I only added 3 tablixes, and all are hidden because the SortBy value doesn’t match the string in the expression.
