We use the STD method, and change the STD cost irregularly, and don’t use cost roll-up feature.(only entered manually)
So I want to see who made what changes and when for each part. Past change history.
Has anyone created this report? Could you please give me some advice on how to create this report in BAQ?
Thanks in advance!
Hi,
Actually, I created BAQ that filter it down by “ADJ-CST” in the PartTran.TranType column. However, we have various ADJ-CSTs in addition to this STD adjustment. For example, ADJ-CST also appears when PPV occurs. So I only want to see the details that the user entered in Cost Adjustment.
Of course I can filter by Reason code, but I can’t filter out cases where the user accidentally enters a different Reason code. So I only want to see the details entered in this Cost Adjustment menu.
Table PartCost holds the current cost
Table CostPart shows the history, which cost group changed the part cost and if you bring in the group table, who did it.
After further looking at it, this only works for the costing workbench. I would stick with the previous suggestion, look for ADJ-CST transactions on PartTran. There is a reference field on that screen that flows through to PartTran. Maybe a screen customization could populate that with something for you to filter by.
