Supplier Security Question - V803.409c
There is likely a better way to do this, but I don't know it. That said, you
can create a quick search that only shows the appropriate records and set it
as the base search on the appropriate fields. If the security is a big
issue, it might not be the best approach as it's pretty easy to revert to
the base search and I'm not sure you can lock down that functionality.
But if it's just a business process issue, that may a quick and easy
solution.
On Mon, Jul 18, 2011 at 1:46 PM, nancy.leifheit <nleifheit@...>wrote:
> I need to limit an employee to only search (whether in PO entry or Supplier
> Tracker)for suppliers they are authorized to write PO's for?
> Seems once I am in PO Entry or Supplier Tracker I can get all suppliers
> (from our President to production floor employees).
> I thought Vendor Group - creating a special group for those suppliers they
> could search and enter po's for, but not certain how to proceed.
> I would appreciate any suggestions from the group.
> Thank you in advance.
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
I need to limit an employee to only search (whether in PO entry or Supplier Tracker)for suppliers they are authorized to write PO's for?
Seems once I am in PO Entry or Supplier Tracker I can get all suppliers (from our President to production floor employees).
I thought Vendor Group - creating a special group for those suppliers they could search and enter po's for, but not certain how to proceed.
