On Tue, Jun 17, 2014 at 1:24 AM, SimsTrak <simstrak@...> wrote:
Â
We are using the ready to process checkbox in Order Entry, but would like to programmatically suppress (at times) the “Do you want to set this order Ready to Process†dialog box that comes up when you navigate away from the order.  Depending on what the user is doing, there are times I will want to suppress that message, other times I’ll want Epicor to just run normally (meaning prompt if it’s not set, no prompt if it’s set).  Is there a way in a customization or in a BPM I can turn that off?
Â
Thanks.
Kevin Simon
Bumping this - seeing if anyone has any input.Â
We are using the ready to process checkbox in Order Entry, but would like to programmatically suppress (at times) the “Do you want to set this order Ready to Process” dialog box that comes up when you navigate away from the order. Depending on what the user is doing, there are times I will want to suppress that message, other times I’ll want Epicor to just run normally (meaning prompt if it’s not set, no prompt if it’s set). Is there a way in a customization or in a BPM I can turn that off?
Thanks.
Kevin Simon
