Switch statement in app studio
Does anyone know what syntax should go in a switch statement? I am very confused, it says expression like a condition which makes sense but what would I set it equal to? I want it to be equal to whatever is under the parameter here:
But I am not sure how to reference that here:
If anyone knows let me know, I cant seem to find a forum post about it unless maybe I missed it. Thanks!
I didn’t use expression at all. But you could write a JS expression if needed. that’s what is being evaluated.
I just used the “Value” field there…
Example: I have Value set to {TransView.MyColumn}
Based on the resulting value… you go into Parameters and create your Case Statements
Case Statements (let’s say you create 3 or more):
Value: A
Value: B
Value: C
So if the value of {TransView.MyColumn} is “A”… the event follows down that branch (action).
I value is “B”… the event follows down that branch (action)…
etc.
Sorry… here’s some screen shots that might be helpful:
13 different Case Statements:
Which each look like this:
This is for our barcode scanners scanning into MES. So they just scan a value into a text field. Column Change event fires and this switch takes over.
if they scan in a barcode value of:
STARTPROD… do this stuff start production stuff
STARTSU… do this start setup stuff
STARTIND… do this start indirect labor stuff
Here’s the final event:
hmm weird mine doesnt seem to be working when I do that, maybe I need to be using transview or something else besides CallContextBpmData, or is my syntax wrong somehow?
setup looks okay. Can you see anything happen in debugger?
I mean something is happening, but no mention of our character field
yeah, mine doesn’t say anything either about the Transview field I’m referencing… so that’s probably normal.
What kind of action are you trying to do afterwards to show that it is working?
I was able to get the CallContextBpmData.Character01 field and other fields to populate in the Console log by having the Value equal to “switch” and the expression to {TableName.FieldName}.
Thought of calling a function?
That was my first thought also.
I just have a dialog show, here is a screenshot, and I am testing on a button click just to prove this out
Yeah I mean at this point I guess I might as well, I can also accomplish this by using conditionals instead, I was just kinda curious about how this switch statement works exactly
all good. just saw the tall switch stack and was like whoa
I thought dialog-show was deprecated. I always use message-handler. Not sure if that plays into this or not.
okay I did switch it over, but I did notice I am getting a different error code now:
It looks like the expression evaluator is trying to treat Pending as a variable and evaluate it, try surrounding with single quotes ‘Pending’
same thing with single quotes
hmm, that still looks like appstudio is trying to Eval it as an expression, i wonder if you check the Dev Tools Network tab for the json in “Preview” or “Response” for the GetApp call on the draft preview, if its really saving it with the single quotes, check in the json, i suspect it’s still saving as “Pending” vs. “‘Pending’”
Guessing this is the line you are referring to? It does look like it is set to just “Pending” instead of “‘Pending’”
So I added the single quotes on the row update and I got this error:
But I guess I am going about this the wrong way? If anyone knows let me know. Thanks for the help everyone!
Try with double quotes? I’ve done it this way before but it was at a previous company so I don’t have the dashboard to look at/reference unfortunately. From memory I think it was single quotes, but it might have been on the expression and not the value.
You could try to put the (single or double) quotes around the expression in the switch too “{CallContextBpmData.Character01}”
