Switching tabs Blank Title 104030
You can also use the csm to pull a reference to the control using the guid.
Cast it back to a tab and call 'focus'.
Either way works, but this'll save you a couple lines of code.
On Tue, Sep 13, 2011 at 1:16 PM, sanfordm99 <sanfordm99@...> wrote:
> That worked Great! You were right about the names, I would have never
> guessed.
> Thanks for the help,
> -Mike
> --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> > I have done it this way, there may be better ways.....
> > Imports System.Reflection
> > Imports System.Collections
> > Define a variable to work with in your code:
> > Private pnlMyPanel As New
> Infragistics.Win.UltraWinDock.DockableControlPane()
> > Create a Sub to loop through the panels and assign your variable to the
> panel you want:
> > Private Sub FindMyPanel(Optional ByRef ctls As
> System.Windows.Forms.Control.ControlCollection = Nothing)
> > ' Enumerate the forms controls looking for the Epicor dock manager
> > If ctls Is Nothing Then ctls = oTrans.EpiBaseForm.Controls
> > For Each ctl As Control In ctls
> > If ctl.HasChildren Then FindMyPanel(ctl.Controls)
> > If TypeOf(ctl) Is Infragistics.Win.UltraWinDock.WindowDockingArea Then
> > Dim objDockManager As Object = ctl.GetType ().InvokeMember("DockManager",
> BindingFlags.GetProperty Or BindingFlags.NonPublic Or BindingFlags.Instance
> Or BindingFlags.IgnoreCase, Nothing, ctl, Nothing)
> > ' Once found get a handle to the Infragistics dock manager using
> relection
> > Dim udm As Infragistics.Win.UltraWinDock.UltraDockManager = CType
> (objDockManager, Infragistics.Win.UltraWinDock.UltraDockManager)
> > For Each p As Infragistics.Win.UltraWinDock.DockableControlPane In
> udm.ControlPanes
> > If (p.Key.ToString = "<the name of the panel you are looking for>") Then
> > pnlMyPanel = p
> > End If
> > 'MessageBox.Show(p.ToString())
> > Next
> > End If
> > Next
> > End Sub
> > Call the Sub in the Form Load event
> > then you use pnlMyPanel.Activate() or pnlMyPanel.Close() to control the
> panel
> > Sometimes the panle names are not intuitive - uncomment
> 'MessageBox.Show(p.ToString()) to show the names of all the panels as they
> are looped through to find the name of the desired panel
> > As always - the group message editor mangles long lines so beware of line
> wrapping if you copy and paste code
> > bw
> > --- In vantage@yahoogroups.com, "sanfordm99" <sanfordm99@> wrote:
> > > How can I switch tabs on a form, such as UD101. I have a button on the
> child detail panel, that should switch the view back to its parent
> (detailPanel1) after completing its code. I have tried a few things such as
> UD101Form.ActivateSheet("detailPanel1") without any luck.
> > > Thanks,
> > > Mike
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
How can I switch tabs on a form, such as UD101. I have a button on the child detail panel, that should switch the view back to its parent (detailPanel1) after completing its code. I have tried a few things such as UD101Form.ActivateSheet("detailPanel1") without any luck.
Mike
Private pnlMyPanel As New Infragistics.Win.UltraWinDock.DockableControlPane()
Create a Sub to loop through the panels and assign your variable to the panel you want:
Private Sub FindMyPanel(Optional ByRef ctls As System.Windows.Forms.Control.ControlCollection = Nothing)
Dim objDockManager As Object = ctl.GetType ().InvokeMember("DockManager", BindingFlags.GetProperty Or BindingFlags.NonPublic Or BindingFlags.Instance Or BindingFlags.IgnoreCase, Nothing, ctl, Nothing)
' Once found get a handle to the Infragistics dock manager using relection
Dim udm As Infragistics.Win.UltraWinDock.UltraDockManager = CType (objDockManager, Infragistics.Win.UltraWinDock.UltraDockManager)
For Each p As Infragistics.Win.UltraWinDock.DockableControlPane In udm.ControlPanes
pnlMyPanel = p
End If
Next
End If
Next
End Sub
then you use pnlMyPanel.Activate() or pnlMyPanel.Close() to control the panel
Sometimes the panle names are not intuitive - uncomment 'MessageBox.Show(p.ToString()) to show the names of all the panels as they are looped through to find the name of the desired panel
As always - the group message editor mangles long lines so beware of line wrapping if you copy and paste code
bw
> Thanks,
> Mike
That worked Great! You were right about the names, I would have never guessed.
-Mike
> pnlMyPanel = p
> End If
> Next
> End If
> Next
> End Sub
> bw
> > Thanks,
> > Mike
