System.Data.DataSetExtensions assembly
I am trying to add System.Data.DataSetExtensions in a UI Customization Custom Assembly Reference with no luck. My guess it is because it is a System Assembly and not a Epicor or User Assembly.
Wondering if there is a way. I want to be able to use IQueryable and/or IEnumerable in a LINQ query.
Scott
you could manually drop the dll in the client folder but that’s generally not recommended.
Yea, I don’t want to do that. I guess it is a foreach loop then.
That’s all that LINQ does in the back end anyways
Yea, I was looking to convert a DataSet to a .AsQueryable so I did not have to loop through it. I like to use .Any if I am looking for a condition in multiple rows
You can do Select and use the SQL Syntax
DataSet.Table[0].Select(“MyField = 33”)
Nice, I did not think of that. Thanks
