Tab label 0 characters wide in dashboard
I have created a dashboard that contains three queries. In Designer mode I see all three just fine. When I test the dashboard (Tools | Deploy Dashboard, then click Test Application), the third tab has no label and the user cannot even tell it’s there unless he happens to hover over the spot where the 0-width label is.
I have tried comparing the properties of the third query with the two that do show up, but cannot see a difference.
This third query does have a subquery embedded; the other two do not. It does not seem like that should make a difference, but maybe it does? We are on 10.1.500.10.
Thanks.
So it seems that changes are not visible to the Test Application function unless you close down Epicor and re-login. Not at all an ideal solution, but it works. Found this by accident.
If anyone has a way to make the changes “take” and be tested without shutting down the whole app, I would appreciate knowing about it.
Thanks.
