I am doing a Method Directive Post-Processing on Erp.BO.Labor.Update and added the following code (referencing Erp.Contracts.BO.ReceiptsFromMfg).
Getting an error saying:
SelectSerialNumbersParamsTableset exists in both Erp.Contracts.BO.Labor and Erp.Contracts.BO.ReceiptsFromMfg
using (Erp.Contracts.ReceiptsFromMfgSvcContract receiptMfgSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.ReceiptsFromMfgSvcContract>(Db))
foreach(var r in ds.LaborDtl)
I am getting this error when trying to save back at the Method Directive screen:
System Information
Form Name: Method Directives
Customization Name:
Menu ID: BPMN1200
Software Version: 4.3.200.0
Server Side Exception
There is at least one compilation error.
CustomizationAdapter.cs(503,30): error CS0433: The type âSelectSerialNumbersParamsTablesetâ exists in both âErp.Contracts.BO.Labor, Version=11.3.200.0, Culture=neutral, PublicKeyToken=5d3fa3c7105d7992â and âErp.Contracts.BO.ReceiptsFromMfg, Version=11.3.200.0, Culture=neutral, PublicKeyToken=5d3fa3c7105d7992â
CustomizationAdapter.cs(9,132): error CS0738: âLaborSvcCustomizationâ does not implement interface member âLaborSvcContract.GetSelectSerialNumbersParams(ref LaborTableset, int)â. âLaborSvcCustomization.GetSelectSerialNumbersParams(ref LaborTableset, int)â cannot implement âLaborSvcContract.GetSelectSerialNumbersParams(ref LaborTableset, int)â because it does not have the matching return type of âSelectSerialNumbersParamsTablesetâ.
Error Detail
##!Correlation ID:##! 0b04446d-f7ca-4272-ba18-f60e0ab84400
##!Description:##! There is at least one compilation error.
##!Details:##!
##!Program:##! Epicor.Customization.dll
##!Method:##! MoveNext
##!Line Number:##! 73
##!Column Number:##! 17
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
at Epicor.ServiceModel.Channels.ImplBase.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Epicor.ServiceModel.Channels.ImplBase.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Proxy.BO.BpMethodImpl.Update(BpMethodDataSet ds)
at Ice.Adapters.BpMethodAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Ice.UI.App.BpMethodEntry.Transactions.MainTransactionBase.adapterUpdate()
