Here's a snippet from a project I did on a UD table... This example also shows how to hide items, as well as add a menu item to the actions tool bar and execute code when that is clicked on.
using Infragistics.Win.UltraWinToolbars;
this.baseToolbarsManager.ToolClick += new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClick);
//this.newTool.ToolClick += new System.EventHandler(this.newTool_ToolClick);
object obj = typeof(Epicor.Mfg.UI.App.UD25Entry.UD25Form).InvokeMember("baseToolbarsManager", BindingFlags.Instance | BindingFlags.GetField | BindingFlags.NonPublic, null, UD25Form, null);
baseToolbarsManager = (Infragistics.Win.UltraWinToolbars.UltraToolbarsManager)obj;
//adaptUD25 = new UD25Adapter(UD25Form);
HideTools();
private void UD25Form_Load(object sender, EventArgs args)
// Add Event Handler Code
ButtonTool newTool = new ButtonTool("Unapproval");
//Set the properties
newTool.SharedProps.Caption = "Unapprove";
newTool.SharedProps.Enabled = true;
newTool.SharedProps.Visible = true;
newTool.SharedProps.AppearancesSmall.Appearance.Image = EpiUIImages.SmallEnabledImages.Images[EpiUIImages.IndexOf("Print")];
//first add the tool to the baseToolbarsManager
baseToolbarsManager.Tools.Add(newTool);
//add the above created tool into Standard Tools toolbar
//baseToolbarsManager.Toolbars["Standard Tools"].Tools.AddTool("Unapproval");
//add the above created tool into file menu in the Main Menu
((PopupMenuTool)baseToolbarsManager.Tools["ActionsMenu"]).
newTool.ToolClick += new ToolClickEventHandler(newTool_ToolClick);
private void newTool_ToolClick(object sender,ToolClickEventArgs args)
edvUD25.dataView[edvUD25.Row].BeginEdit();
edvUD25.dataView[edvUD25.Row]["CheckBox03"] = false;
edvUD25.dataView[edvUD25.Row]["CheckBox07"] = false;
edvUD25.dataView[edvUD25.Row]["CheckBox08"] = false;
edvUD25.dataView[edvUD25.Row]["CheckBox09"] = false;
edvUD25.dataView[edvUD25.Row]["CheckBox10"] = false;
edvUD25.dataView[edvUD25.Row]["CheckBox11"] = false;
edvUD25.dataView[edvUD25.Row].EndEdit();
edvUD25.Notify(new EpiNotifyArgs(UD25Form, edvUD25.Row, edvUD25.Column));
MessageBox.Show("When this CAR is approved, the authorization process will be re-initialized.");
private void baseToolbarsManager_BeforeToolDropdown(object sender, Infragistics.Win.UltraWinToolbars.BeforeToolDropdownEventArgs args)
public void HideTools()
if (baseToolbarsManager.Tools.Exists("NewTool"))
baseToolbarsManager.Tools["NewTool"].SharedProps.Enabled = false;
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:
1.234354861@...]<
http://www.dsmfg.com/>
(Click the logo to view our site)<
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com]
Sent: Thursday, May 14, 2015 1:39 PM
To: EPICOR UG - EPICOR (
vantage@yahoogroups.com)
Subject: [Vantage] TAF: baseToolbarsManager ToolClick or execute
Hello
Does anyone know how to call/execute any of the toolbar options from a customization in E9? (SaveTool, ClearTool, etc)
I am looking for something like button.PerformClick() but with something like baseToolbarsManager.Tools("SaveTool ").ToolClick() or whatever.
Any ideas or help would be appreciated.
I have looked in the ICE documentation, but have not seen anything about methods and calls.
