Bryan, we are on 905.700C and had the same issue. The flag on the company settings does not do anything so I had to write a BPM. I can send it to you if you would like
Sent: Tuesday, February 12, 2013 1:30 PM
Subject: [Vantage] Taxable flag on the PO line checked by default. Epicor 9.05.700C
Â
Hello,
We have just recently converted to Epicor 9.05.700C and most things are going good. I have ran into this issue and I am sure someone else has before. The taxable checkbox is checked by default and we need it to be uncheck to keep from causing issues. I contacted support and below is what I was told.
"WORKAROUND:
Uncheck the taxable flag on the PO line manually or set up a BPM"
Has anyone set this BPM up before? If so, any kind of input or help on it would be awesome!
Thank you,
Bryan
Â
Hello,
"WORKAROUND:
Thank you,
Bryan
