Thanks Carl!
That worked!
That worked!
--- In vantage@yahoogroups.com, "Carl Peterson" <cpeterson@...> wrote:
> Jasper:
> Go to your Progress ProExplorer - select your test database under
databases,
> select configuration line, right click on the defaultconfiguration
line and
> select properties - General tab - change the # Lock Table entries
line - I
> would add 20000 to the value - Press ok to save - This will change
the -L
> value for you. Usually, the initial value is under 10000.
> This value needs to be increased if you are loading records.
> You will need to shut down your test db server and then restart the
test db
> for the change to work.
> Good luck.
> Carl Peterson
Behalf Of
> Jasper Recto
> Sent: Tuesday, January 06, 2009 11:20 AM
> To: Vantage Groups (vantage@yahoogroups.com)
> Subject: [Vantage] Test database error
> I'm getting this error on my test database.
> Lock table overflow, increase -L on server (915)
> How do I fix this?
> Jasper
