Hi,
We are posting time and expense to jobs via DMT, and we double posted a batch. So, I go into Time and Expense Entry and there they are, two sets of postings.
I changed the labor quantity to zero on the first job/line and it worked fine. On subsequent lines when I change the quantity to zero I get:
Server Side Exception
Input string was not in a correct format.
Error Detail ============Description: Input string was not in a correct format.Program: CommonLanguageRuntimeLibraryMethod: StringToNumberOriginal Exception Type: FormatExceptionFramework Method: AddHoursFramework Line Number: 0Framework Column Number: 0Framework Source: AddHours at offset 6246 in file:line:column <filename unknown>:0:0
Server Trace Stack: at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseDecimal(String value, NumberStyles options, NumberFormatInfo numfmt) at Compatibility.Convert.ToDecimal(String strValue)...
I've tried 0, 0.0, etc., but still get this message.
Ideas?
Joe
Joe D. Trent
Bigham Ag Equipment
Call support…I had a 1-off sent to me for T/E issues…
Sent: Monday, November 30, 2015 3:36 PM
Subject: [Vantage] Time And Expense Entry E10.700.4 - Input string was not in a correct format.
Hi,
strValue)...
Ideas?
Joe
Joe D. Trent
Bigham Ag Equipment
