My company has just revised their scrap reason codes and they have asked if its possible to have a second drop down with sub-reasons based on the first reason selected? For example, If i chose the scrap reason, Bad Part, a second drop down would be visible with the options for a more specific Bad Part scrap reason. But if i chose a different primary scrap reason, the secondary would be related to that specific primary scrap reason. I have attached an example below. Thanks is advance for the help!
correct! this request is just to get a more accurate account of the scrap that runs through our foundry. Better cost analysis, trends, general metrics that the engineering, accounting, and other admins wish to see.
i already have a dashboard created that pulls anything that reports scrap. Being able to see how often a scrap reason (+secondary) appears can help identify if the problems appear at the same process each time or if there is another variable we need to consider.
My vision for the dashboard would have an additional column next to Scrap reason labeled “Sub-Scrap Reason” and would be filled with whatever the operator chose depending on the primary reason; or blank if its not applicable.
