Time Phase Material report
Thanks anyways and thanks for all you help!
Jasper
Sent: Wednesday, February 25, 2004 9:04 AM
Subject: RE: [Vantage] Time Phase Material report
I did not overcome this issue in report builder. Fortunately in my case we
have just one warehouse.
Patrick Winter
Sent: Wednesday, February 25, 2004 7:27 AM
Patrick,
In your report, how did you calculate the beginning On-hand Quantity if you
have a single part in multiply warehouses? If I just use the
Partwhse.onhandqty, my report will be all wrong because sometimes we have a
part in different warehouses. How did you add up the on-hand qty from each
warehouse?
Jasper
Sent: Wednesday, February 18, 2004 4:52 PM
Jasper,
I cut and pasted these for you.
A2 = IIF(PREVIOUS(PartDtl.JobNum) = PartDtl.JobNum,0, ProdQty - ReceivedQty
- ShippedQty)
B2 = IIF(PREVIOUS(PartDtl.OrderNum) = PartDtl.OrderNum AND
PREVIOUS(PartDtl.OrderLine) = PartDtl.OrderLine AND
PREVIOUS(PartDtl.OrderRelNum) = PartDtl.OrderRelNum,0,OurReqQty -
OurStockShippedQty - OurJobShippedQty)
C2 = IIF(SourceFile = 'JH' and RecordCount = 1,C2 + A2 + InventoryOnHand,
IIF(SourceFile = 'OR' and RecordCount = 1,C2 - B2 + InventoryOnHand,
IIF(SourceFile = 'JH', C2 + A2, IIF(SourceFile = 'OR',C2 - B2,C2))))
Patrick Winter
Sent: Wednesday, February 18, 2004 3:44 PM
In your calculation, what does the A2, B2, C2 stand for?
Jasper
Sent: Tuesday, February 17, 2004 9:15 AM
You can create the Time Phase Report in Report Builder but it's not easy.
Manufactured Parts Version of TimePhase.
I used the PartDtl and joined to the Part Table.
Then did outer joins to the JobHead, OrderRel, and PartWhse.
PartWhse gives you the onhand starting quantity for the part.
Sort and Group on Part.Description and PartDtl.DueDate Filter for
PartDtl.Source INLIST 'JH','OR'
I came up with this calculated field to calculate the running balance.
RunBalance =
The trick was adding in the starting onhand quantity.
The way this is designed will only run for one manufactured part, it would
need to have more logic added to run multiple parts or purchased parts.
Good Luck.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.20.322, Progress 9.1D, Windows 2003 Server
Sent: Monday, February 16, 2004 2:09 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Time Phase Material report
Can anybody explain to me what information the Time Phase material report
gives you. What criteria does it use to calculate a projected balance?
Does it take into account manufacturing lead time and vendor lead time? Can
it tell you when to order materials? Any information would help.
Also, any ideas on how to recreate this report in report builder?
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Can anybody explain to me what information the Time Phase material report gives you. What criteria does it use to calculate a projected balance? Does it take into account manufacturing lead time and vendor lead time? Can it tell you when to order materials? Any information would help.
Jasper
Filter for PartDtl.Source INLIST 'JH','OR'
RunBalance =
Good Luck.
Patrick Winter
Jasper
Yahoo! Groups Links
Wow,
Thanks Patrick, I'll give this a go!
Jasper
RunBalance =
Good Luck.
Patrick Winter
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Jasper
RunBalance =
Good Luck.
Patrick Winter
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Jasper,
- ShippedQty)
Patrick Winter
Jasper
RunBalance =
Good Luck.
Patrick Winter
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Patrick,
In your report, how did you calculate the beginning On-hand Quantity if you have a single part in multiply warehouses? If I just use the Partwhse.onhandqty, my report will be all wrong because sometimes we have a part in different warehouses. How did you add up the on-hand qty from each warehouse?
Jasper
Jasper,
- ShippedQty)
Patrick Winter
Jasper
RunBalance =
Good Luck.
Patrick Winter
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Patrick Winter
Patrick,
warehouse?
Jasper
Jasper,
- ShippedQty)
Patrick Winter
Jasper
RunBalance =
Good Luck.
Patrick Winter
Jasper
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
