DMT has Job labor Adjustment under Production Adjustments. You should be able to do thru this. the fields available are.
ClockInDate
AssemblySeq
OprSeq
EmployeeNum
LaborQty
LaborType
LaborHrs
LaborCost
BurdenHrs
BurdenCost
Complete
OpComplete
company
LaborHedSeq
LaborDtlSeq
OpCode
ResourceGrpID
JcDept
JobNum
Plant
I have version 1.0.4.5 for 905.700.
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of robelesde
Sent: Friday, November 09, 2012 7:47 AM
Subject: [Vantage] Timesheet entry
Hello,
I'm new to the group and have already learnt a lot - thanks for the tips!
We are not yet using MES and are entering employee time from daily paper timesheets through time and expense entry.
This is taking a long time and it would be much easier if we could cut and paste all the entries from a spreadsheet, however there doesn't seem to be a way to do this across multiple employees either in time and expense entry or using DMT.
Does anyone have a way around this?
Thanks in advance for your help. Our thoughts go out to all US members still cleaning up from Hurricane Sandy.
Rob McMahon
EL ES DE Engineering
Perth, Western Australia
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
ClockInDate
AssemblySeq
OprSeq
EmployeeNum
LaborQty
LaborType
LaborHrs
LaborCost
BurdenHrs
BurdenCost
Complete
OpComplete
company
LaborHedSeq
LaborDtlSeq
OpCode
ResourceGrpID
JcDept
JobNum
Plant
Greg Payne
Hello,
Rob McMahon
