Doug.C
(Doug Crabtree)
2
They are found on the APP Server in the directory where Epicor is installed. Then you navigate to:
...\Websites\<<InstanceName>>\Server\BPM\Sources
Remember though, there are many versions in those directories, so you will only want the latest one.
What you most likely will look for are ones that make direct joins from Db.<<tablename>> to the temporary tables.
