Thanks Sarah! Problem solved.
> From: sarah.vareschi@...[SMTP:sarah.vareschi@...]
> Reply To: vantage@egroups.com
> Sent: Friday, September 29, 2000 8:40 AM
> Subject: RE: [Vantage] Tracker Access in 4.0
> Rick, from within the tracker section, there is subcomponent security on
> every tracker, and even some subcomponent security under that. From my
> experience, we have been able to keep everybody out of what they don't
> need
> to see by using subcomponent security. This can be accessed through
> System
> Management/ Security maintenance/ menu security. Then, under executive
> analysis, you will see trackers, double-click trackers, and every tracker
> will be listed. Now, you can assign security to each tracker.
> Sarah
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
