I don't know if others have offered this response yet but we add the die (tool) in the BOM and backflush it based on the number of parent parts received into stock. That way the negative on-hand balance for the die tells you the number of hits on the tool. We have gone further and developed an add-on tooling management solution that allows engineering personnel to establish tooling trigger points based on the number of hits on each tool and when the system should alert them that a tool has surpassed its hit trigger limit and a tooling inspection process is due.
[cid:image002.jpg@...174780]
Dale Walker
Director, Information Technology
Le Sueur Incorporated
1409 Vine Street
Le Sueur, MN 56058
ph.507.665.6204 x277
fx .507.665.8466
www.lesueurinc.com<http://www.lesueurinc.com>
Dale Walker
1409 Vine Street
Le Sueur, MN 56058
fx .507.665.8466
