Hello!
We are intermittently seeing these sorts of lockouts:
System.Data.Entity.Core.EntityCommandExecutionException: An error occurred while reading from the store provider’s data reader. See the inner exception for details. —> System.Data.SqlClient.SqlException: Lock request time out period exceeded.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryHasMoreRows(Boolean& moreRows) at System.Data.SqlClient.SqlDataReader.TryReadInternal(Boolean setTimeout, Boolean& more) at System.Data.SqlClient.SqlDataReader.Read() at System.Data.Entity.Core.Common.Internal.Materialization.Shaper
1.StoreRead()
— End of inner exception stack trace —
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper1.HandleReaderException(Exception e) at System.Data.Entity.Core.Common.Internal.Materialization.Shaper
1.StoreRead()
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper1.SimpleEnumerator.MoveNext() at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable
1 source)
at System.Data.Entity.Core.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues)
at System.Data.Entity.Core.Objects.CompiledQuery.Invoke[TArg0,TArg1,TResult](TArg0 arg0, TArg1 arg1)
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass33_13.<Compile>b__3(TContext c, Func
3 query) in C:_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1089
at Epicor.Data.DBExpressionCompiler.GetResult[TContext,TQuery,TResult](Func3 executeQuery, Cache cacheSetting, TContext dataContext, TQuery query) in C:\_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 445 at Epicor.Data.DBExpressionCompiler.InvokeSingle[TContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func
2 getDataCacheKey, Func2 compileQuery, Func
3 executeQuery) in C:_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 306
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass33_03.<Compile>b__0(TContext context, TArg1 arg1) in C:\_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1082 at Erp.Tables.OrderRel.FindFirstBySysRowIDWithUpdLock(ErpContext dataContext, Guid sysRowID) in C:\_projects\ERP\RL10.2.300.0\Source\Server\Db\Erp.Data.910100\ErpContext.Model.cs:line 1597973 at Erp.Services.BO.SalesOrderSvc.GetDBRowWithUpdLock(Int32 tableNumber, Guid rowID) in C:\_Releases\ERP\UD10.2.300.15\Source\Server\Services\BO\SalesOrder\SalesOrder.Designer.cs:line 420 at Ice.TablesetBound
3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, IColumnUncensor uncensor, TablesetProfilingCollector parentTraceCollector) in C:_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1246
at Ice.TablesetBound3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 974 at Ice.TablesetBound
3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in C:_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 866
at Erp.Services.BO.SalesOrderSvc.Update(SalesOrderTableset& ds) in C:_Releases\ERP\UD10.2.300.15\Source\Server\Services\BO\SalesOrder\SalesOrder.Designer.cs:line 3898
at Epicor.Customization.Bpm.MethodCustomizationBase23.RunDirectives(TParam parameters) in C:\_Releases\ICE\ICE3.2.300.15\Source\Server\Internal\Lib\Epicor.Customization.BPM\MethodCustomizationBase2.cs:line 197 at Epicor.Customization.Bpm.CustomizationBase2
3.Execute(TParam parameters) in C:_Releases\ICE\ICE3.2.300.15\Source\Server\Internal\Lib\Epicor.Customization.BPM\CustomizationBase2.cs:line 73
at Epicor.Customization.Bpm.BO50B63956D3AF4C44970D4E5949F9D4D6.SalesOrderSvcCustomization.Update(SalesOrderTableset& ds)
at Erp.Services.BO.SalesOrderSvcFacade.Update(SalesOrderTableset& ds) in C:_Releases\ERP\UD10.2.300.15\Source\Server\Services\BO\SalesOrder\SalesOrderSvcFacade.cs:line 9195
at Ice.TablesetBound`3.CallUpdate(Object serviceObject, TFullTableset& workingTs, BOUpdErrorTableset errors, IceRow originalParentRecord) in C:_Releases\ICE\ICE3.2.300.15\Source\Framework\Epicor.Ice\Services\TablesetBound.UpdateExt.cs:line 1333’
I’d like to make sure it is not a BPM that would be causing the lock…how can I go about matching the ID given in the error to the bpm id?
