Trans date and sys date way off
We find PO receipts with strange dates. I'm still trying to track it down, but it appears if you make a change to a PO reciept or try to fix it, it goes back to the original PO date??
So yes, we get strange dates, but I'm not sure where they are all coming.
--- In vantage@yahoogroups.com, "Karen Schoenung" <kschoenung@...> wrote:
> Hi,
> We are on 8.03.409c and found that the Ship Date and the Inventory
> Transfer date can be overridden. We found a couple of dates where a
> user put in a quantity instead of a date and it is accepted. So quantity
> of 152 = 01/05/2002. We have just recently put in code to have this
> field read only.
> I am not sure if this would be the same case for pur-ins and mfg-stk,
> but you could probably test by using your TEST system to see if the date
> can be overridden.
> Of Trzaska, Mark
> Sent: Wednesday, January 12, 2011 10:46 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] trans date and sys date way off
> Hi all,
> Did or does anyone have a problem with transaction date verification.
> When out acct closes for the month there are multiple transactions with
> a trans date that is 3 to 4 months different then the sysdate. Doesn't
> matter if its pur-ins or mfg-stk etc etc
> We are on 8.03.408b
> thanx
Hi all,
Did or does anyone have a problem with transaction date verification. When out acct closes for the month there are multiple transactions with a trans date that is 3 to 4 months different then the sysdate. Doesn't matter if its pur-ins or mfg-stk etc etc
We are on 8.03.408b
thanx
Hi,
field read only.
can be overridden.
Of Trzaska, Mark
Hi all,
We are on 8.03.408b
thanx
