We have been able to run vantage quite reliably directly over a VPN (V
8.03.405A). This is a Cisco hardware to hardware VPN, but it has been
very reliable and has eliminated the need for terminal services for us.
One thing that I have seen cause this issue is the power savings
settings on the network card driver. Even if your computer does not go
to hibernate overnight, it may shut down the network card to "save power".
It's worth a check.
Aaron Hoyt
Vantage Plastics
It's worth a check.
Aaron Hoyt
Vantage Plastics
>[Non-text portions of this message have been removed]
> One of the things I would suggest is to not run Vantage directly
> within a VPN tunnel. That communication is to unreliable to be of much
> use for running Vantage. Let them connect VPN but then have them run
> Vantage using a terminal server session or a remote desktop session to
> a local machine. That way, when communication is lost they simply
> reconnect to the remote session and they are right back where they were.
> From: Brian W. Spolarich
> Sent: Thursday, September 25, 2008 10:08 AM
> Subject: [Vantage] "Tried to call a method in an invalid procedure" Errors
> I'm curious if others have seen this error. Occasionally I'll come
> back to work in the morning having left my Vantage client running
> overnight. I will see this error: "Tried to call a method in an invalid
> procedure. (7224)" I will also see this error when I disconnect/undock
> my laptop if I have Vantage running, or if I restart the MfgSys803
> appserver, so it seems to indicate that the client has lost its
> connection. I don't see evidence of problems on the Vantage server
> logs, nor other evidence of network issues on my LAN.
> Users also see this when connecting the Vantage client via VPN, either
> from a remote office or from home, after a few minutes of idle time.
> Because of this we're planning on deploying Vantage via Citrix for the
> remote offices. But it seems troubling that this would be happening
> even over a LAN (although I haven't heard reports of disconnects like
> this during the day).
> Ideas?
> Thanks! -brian
> Error Detail
> Tried to call a method in an invalid procedure. (7224)
> Stack Trace
> at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
> procedureName, ParameterSet parms, MetaSchema schema)
> at Epicor.Mfg.Proxy.GenXDataImpl.StoreData(GenXDataDataSet ds)
> at Epicor.Mfg.UI.FrameWork.GenXObject.StoreData(GenXDataDataSet ds)
> at Epicor.Mfg.UI.FrameWork.GenXObject.handleChunkAndSave(Boolean
> doCompression, String company, String productID, String typeCode, String
> key1, String key2, String key3, String description, String version,
> Boolean layerWIP, String data)
> at Epicor.Mfg.UI.FrameWork.GenXObject.ChunkNSaveStringByID(String
> company, String productID, String typeCode, String key1, String key2,
> String key3, String description, String version, Boolean layerWIP,
> String data)
> at Epicor.Mfg.UI.FrameWork.FormFunctions.ChunkNSaveStringByID(Object
> sender, String company, String productID, String typeCode, String key1,
> String key2, String key3, String description, String version, Boolean
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... <mailto:bspolarich%40advancedphotonix.com>
> <mailto:bspolarich@...
> <mailto:bspolarich%40advancedphotonix.com>> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advancedphotonix.com
> <http://www.advancedphotonix.com>>
