<div id="ygrps-yiv-1325978839yiv6855849671ygrp-text">
<div>I wrote a little .NET utility that can call a few different processes. Basically kick off the process manually in the Epicor client interface, but turn Tracing on first. Then see which Business Object / Method Epicor calls to kick off your process. </div><div><br clear="none"></div><div>For example, One of the processes we kick off with this utility is AutoJobCompletion. </div><div>The Business Object is Epicor.Mfg.Proc.AutoJobCompletion, and the method to call is SubmitToAgent.</div><div><br clear="none"></div><div>You can get an idea for the parameters to set by looking at the trace data, e.g.:</div><div><br clear="none"></div><div><div><br clear="none"></div><div><tracePacket></div><div><span class="ygrps-yiv-1325978839yiv6855849671Apple-tab-span" style="white-space:pre;"> </span><businessObject>Epicor.Mfg.Proc.AutoJobCompletion</businessObject></div><div><span class="ygrps-yiv-1325978839yiv6855849671Apple-tab-span"
style=“white-space:pre;”> <methodName>SubmitToAgent</methodName>
<parameter name='agentID' type='string' ><![CDATA[SystemTaskAgent]]></parameter>
this:
var param = ds.JobCCParam[0];
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mkp #ygrps-yiv-1325978839yiv6855849671hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mkp #ygrps-yiv-1325978839yiv6855849671ads {
margin-bottom:10px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mkp .ygrps-yiv-1325978839yiv6855849671ad {
padding:0 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mkp .ygrps-yiv-1325978839yiv6855849671ad p {
margin:0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mkp .ygrps-yiv-1325978839yiv6855849671ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-sponsor #ygrps-yiv-1325978839yiv6855849671ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-sponsor #ygrps-yiv-1325978839yiv6855849671ygrp-lc #ygrps-yiv-1325978839yiv6855849671hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-sponsor #ygrps-yiv-1325978839yiv6855849671ygrp-lc .ygrps-yiv-1325978839yiv6855849671ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671activity span {
font-weight:700;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671activity span span {
color:#ff7900;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671activity span .ygrps-yiv-1325978839yiv6855849671underline {
text-decoration:underline;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671attach div a {
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671attach label a {
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671bold a {
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 dd.ygrps-yiv-1325978839yiv6855849671last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 dd.ygrps-yiv-1325978839yiv6855849671last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 dd.ygrps-yiv-1325978839yiv6855849671last p span.ygrps-yiv-1325978839yiv6855849671yshortcuts {
margin-right:0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671attach-table div div a {
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671attach-table {
width:400px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671file-title a, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671file-title a:active, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671file-title a:hover, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671file-title a:visited {
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671photo-title a, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671photo-title a:active, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671photo-title a:hover, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div.ygrps-yiv-1325978839yiv6855849671photo-title a:visited {
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 div#ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg #ygrps-yiv-1325978839yiv6855849671ygrp-msg p a span.ygrps-yiv-1325978839yiv6855849671yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671green {
color:#628c2a;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 o {
font-size:0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671photos div {
float:left;width:72px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671reco-category {
font-size:77%;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671reco-desc {
font-size:77%;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 .ygrps-yiv-1325978839yiv6855849671replbq {
margin:4px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg select, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 input, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg pre, #ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 code {
font:115% monospace;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-mlmsg #ygrps-yiv-1325978839yiv6855849671logo {
padding-bottom:10px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-msg p#ygrps-yiv-1325978839yiv6855849671attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-reco #ygrps-yiv-1325978839yiv6855849671reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-sponsor #ygrps-yiv-1325978839yiv6855849671ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-sponsor #ygrps-yiv-1325978839yiv6855849671ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-sponsor #ygrps-yiv-1325978839yiv6855849671ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1325978839 #ygrps-yiv-1325978839yiv6855849671 #ygrps-yiv-1325978839yiv6855849671ygrp-vital ul li:last-child {
border-right:none !important;}
