True/false values in .csv files
Excel can suck when working with CSV files. One alternative is CSVed
http://csved.sjfrancke.nl/.
Obviously if you¹re doing work with formulas, etc. then you¹ll have to
learn to deal with Excel¹s wackinesses, but I¹ve found this utility useful
sometimes.
-bws
On 11/11/08 1:28 PM, "Safi Obaidi" <idiabos@...> wrote:
> I tried preceding the text "true" with the single quote but, after saving as
> .csv the text "true" reverts to "TRUE". I get a notification when saving that
> says "xxx.csv may contain features that are not compatible with CSV."
When uploading data into Vantage via Service Connect, I specify the
value "true" for check boxes that I want checked in my .csv file.
However, after I save the file the value true changes to TRUE (capital
letters). I have tried formatting the cell and using excel formulas
(=LOWER) but after saving the value still changes from true to TRUE.
Anyone know a work around to this issue. Thanks!!
Use a text editor instead, I prefer notepad++
Then do a find and replace matched by CASE. and whole word only.
http://notepad-plus.sourceforge.net
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, November 11, 2008 11:48 AM
Subject: [Vantage] true/false values in .csv files
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
When you type in the text "true" - precede it with a single quote.
That way Excel will treat it as a label. Then save as .csv and you
should be good.
> From: "idiabos" <idiabos@...>
the
(capital
formulas
TRUE.
must
access. )
Builder and
I tried preceding the text "true" with the single quote but, after saving as .csv the text "true" reverts to "TRUE". I get a notification when saving that says "xxx.csv may contain features that are not compatible with CSV."
Sent: Tuesday, November 11, 2008 11:13:43 AM
Subject: [Vantage] Re: true/false values in .csv files
should be good.
> http://notepad- plus.sourceforge .net
> From: "idiabos" <idiabos@... >
> To: <vantage@yahoogroups .com>
the
(capital
formulas
TRUE.
must
access. )
Builder and
> > http://groups. yahoo.com/ group/vantage/ files/.
> > http://groups. yahoo.com/ group/vantage/ messages
> > http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
