Trying to add text to a field in BAQ syntax is not correct
I am trying to create a calculated field that will add a value to an existing field value.
I am taking the VendorID and adding a text onto the back of it. This is part of our tracking for reimplementation from E10 to Kinetic.
     case     When Vendor.KineticVendorID_c = null Then ' '  else Vendor.KineticVendorID_c & '-01'  end
What I am trying to do is to create a calculated field that takes a value and adds -01 to the end of it.
End result would like like this 112233-01
112233 to 112233-01
Any suggestions on how to add the ‘-01’ to a value?
If I use the + instead of the & it does a math calculation which is not what I am looking for
112233 turns into 112232 which is not what I want
What table is the BAQ on, if it is the VEndor table there is no need for the case statement as Vendor ID is a mandatory field, in which case a simple
Vendor.VendorID +‘-01’
gives the desired result.
However, from you post it sounds like you are looking at Vendornum, rather than ID, in which case it would be
convert(varchar, Vendor.VendorNum)+‘-01’
which will do what you want
What is the format of your Vendor.KineticVendorID_c field? It seems like it is acting as a number, so Andy is correct that you need to convert it to a string to add the ‘-01’ at the end.
Converting the field to a varchar - worked great. That is part that I was overlooking.
Thanks for looking at that - it was staring me right in the face.
