Try a post process, also look and see if the method is using parameters
to pass data as well.. like brian mentioned.. some methods don't contain
any data you may be looking to use, but at times they do use parameters
that holds useful information in which you can use to link to the actual
tables that contain the data.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Brian W. Spolarich
Sent: Thursday, February 03, 2011 9:25 AM
Subject: RE: [Vantage] tt Tables
The EmpBasic.ClockOut method does not appear to use temp tables. The
only information available to your BPM are the employeeid and the
shiftid. If you want to use other data in your message you'd need to
find it via a 'find' statement, joining on cur-comp, etc.
-brian
Behalf
Of RICH WAGNER
Sent: Thursday, February 03, 2011 10:21 AM
Subject: [Vantage] tt Tables
I'm trying to write a BPM that displays a message when the user clocks
out of the MES for the day. I am using GetRows with the Labor BO and
have the action set to show informational message based up a template.
My text shows up but when I try to insert a field the field does not
appear.
Can I not assume that just because the ttLaborHed table appears to be a
table I can select that the data is there?
Rich Wagner
2148 Century Drive
Jefferson Hills, PA 15025
Phone: (412) 384-3100 x159
Fax: (412) 384-2033
Rob Bucek
FAX: (715)284-4084
-brian
Behalf
Of RICH WAGNER
appear.
Rich Wagner
2148 Century Drive
Fax: (412) 384-2033
