Message: Severity: Exception, Table: APInvHed, Field: , RowID: 7e5e6f7b-8cc8-4ed2-b8c0-43000195b94c, Text: Only the Due Date, Payments Held, Payment Method, Letter of Credit, Invoice Comments and Recurring Invoice fields can be changed on a posted invoice.
Query returned 1 row(s).
The only fields I have marked as updatable are APInvHed_PMUID and APInvHed_PayHold, which should be in the above list.
I’ve seen references to this issue, but no details on the resolution.
So, I thought I’d just roll my own update, so I used the “Advanced BPM Update Only” and added this code in the update base processing:
Erp.Contracts.APInvoiceSvcContract apInvoice = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.APInvoiceSvcContract>(this.Db, true);
using(var txscope = IceDataContext.CreateDefaultTransactionScope()) //Start Transaction
foreach(var ttResults_xRow in (from row in ttResults
where row.RowMod == IceRow.ROWSTATE_UPDATED
select row))
dsAPInv = new Erp.Tablesets.APInvoiceTableset();
dsAPInv = apInvoice.GetByID(ttResults_xRow.APInvHed_VendorNum, ttResults_xRow.APInvHed_InvoiceNum);
var apInvHed_xRow = (from row in dsAPInv.APInvHed
where row.Company == Session.CompanyID &&
row.VendorNum == ttResults_xRow.APInvHed_VendorNum &&
row.InvoiceNum == ttResults_xRow.APInvHed_InvoiceNum
select row).FirstOrDefault();
if (apInvHed_xRow != null)
//apInvHed_xRow.PayHold = ttResults_xRow.APInvHed_PayHold;
//apInvHed_xRow.PMUID = ttResults_xRow.APInvHed_PMUID;
apInvHed_xRow.RowMod = IceRow.ROWSTATE_UPDATED;
apInvoice.Update(ref dsAPInv);
txscope.Complete(); //Close Transaction
It’s running through the list okay and setting the right fields, but not updating.
If I comment out setting the RowMod to updated the query reports success, but doesn’t update.
When I set the RowMod to updated I get the following error message:
Server Side Exception
BPM runtime caught an unexpected exception of 'ArgumentNullException' type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Correlation ID: 5e105394-f1af-4b03-81ff-e32eda60eddd
Description: BPM runtime caught an unexpected exception of 'ArgumentNullException' type.
Program: Epicor.ServiceModel.dll
Method: Compare
Line Number: 265
Column Number: 33
Original Exception Type: ArgumentNullException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.BO.DynamicQueryImpl.Update(DynamicQueryDataSet queryDS, DataSet queryResultDataset)
at Ice.Adapters.DynamicQueryAdapter.<>c__DisplayClass27_0.<Update>b__0(DataSet datasetToSend)
at Ice.Adapters.DynamicQueryAdapter.ProcessUbaqMethod(String methodName, DataSet updatedDS, Func`2 methodExecutor, Boolean refreshQueryResultsDataset)
at Ice.Adapters.DynamicQueryAdapter.Update(DynamicQueryDataSet queryDS, DataSet updatedDS, Boolean refreshQueryResultsDataset)
at Ice.UI.App.BAQDesignerEntry.BAQTransaction.<CallUpdate>b__379_0(Int32& rowReturned)
at Ice.UI.App.BAQDesignerEntry.Forms.BAQDiagramForm.ShowQueryResults(DataSet dsResults, getQueryResult getResults, ReportAdditionalInfo additionalInfo)
at Ice.UI.App.BAQDesignerEntry.BAQTransaction.CallUpdate()
Inner Exception
Value cannot be null.
Parameter name: Value cannot be null.
Parameter name: toItem
