UD Field not updating
Hi,
Ok to me this is weird, I have added a new UD field to the part table not the first one. all looks good - did the regen the field shows up on a BAQ… However, when I put the field onto a form in part entry, EpiBidning works, all looks good. then run the customized form when I enter into that field ti shows up for every record and does not get updated. I have done this with a bunch of fields before this one, on the same part entry form and they work fine. just when I added this new one it doesn’t take it.
Assuming your 10 version means you are running classic, have you closed and reopen Epicor and cleared cache?
Sometimes it take a kickstart.
Along with what Greg said, double check that you saved the customization with the EpiBinding, I imagine the cache clearing will fix things, but if it doesn’t, double check that. Usually if the same value is carrying over to another record, it’s because that field wasn’t bound properly.
Hi, I tried clearing the cache, same issue… it’s not the epi binding, I can associate the epi binding with another txt box and it works… of course then I lose the other field. It seems to be that I cannot add a txt box to the customization.
Hi, I just tried again, copied an existing field in another group and then changed it to the epi binding I wanted. Worked this time, I don’t know why…
Thank you for the help.
