Hello,
I’m trying to create an updatable BAQ which will be used to update some UD fields on the Customer record. I’ve created the BAQ, but when I try and set it to be updatable I’m getting the below errors relating to the UD field.
Update.Base.##BASE##.cs(95,17): error CS0117: ‘CustomerRow’ does not contain a definition for ‘ShortChar06’
Update.Base.##BASE##.cs(123,58): error CS1061: ‘CustomerRow’ does not contain a definition for ‘ShortChar06’ and no extension method ‘ShortChar06’ accepting a first argument of type ‘CustomerRow’ could be found (are you missing a using directive or an assembly reference?)
I’ve had a look into the system generated BPM, but I haven’t been able to work out how to include any UD fields. Please could somebody point me in the right direction?
