UD Fields Not Showing up as option on Customization
I created three new UD fields in the JobOpe_UD table.
Ran a database REGEN and I can see the fields on SQL.
I was able to add the fields via a customization on Kinetic JobEntry through Application Studio.
Now I am trying to add the fields to the classical Opportunity/Quote Entry → Lines → Manufacturing → Operations Detail via Developer Mode.
However, the fields I created are not being displayed under JobOper in the binding section of the customization screen. Any ideas why?
Did you recycle the app pool?
I would think you’d also have to add the columns to QuoteOpr table.
I stopped the app pool to do the regen. I will try recycling to see if that does the trick.
@dcamlin can you explain your reasoning?
Try the recycle just in case, but if you started it after the regen completed then it should be fine. Did you restart the Epicor client? Maybe clear the cache too just to be sure you’ve got everything up to date.
QuoteOpr… ECOOpr… JobOper are all (3) seperate tables. If you want data to start on the Quote level and end up on the job level, I would think you would need to add the columns to both Quote and Job Op tables.
There is also a UD Column Map menu which has pre-defined mapping and I think the Op tables are included in those pre-defined maps. So, you can tell the program to map the data from QuoteOpr to JobOper.
App Pool recycle did not do the trick. Also @dcamlin I do not see QuoteOpr in the list of available tables for me to choose in the EpiBinding.
No luck. Still not seeing the fields.
Do you see this in UD Column Maintenance?
Actually never mind. Checking it a bit closer, @dcamlin is correct. When you said JobOper binding I assumed that it would be the JobOper table, but for some reason it’s the QuoteOpr table. That’s why you’re not seeing it there. You do need to add the fields to the QuoteOpr table.
He’s also right about the mapping, but I think Epicor automatically passes those fields if the names match. If you find that adding it to QuoteOpr doesn’t transfer it to JobOper when creating the job, then you may need to add it to the QuoteOpr → Job Oper UD Column Map.
@pmarques I see what you mean. I just flew past that since I saw the epibinding pointing to JobOper and recognized the table.
@dcamlin I will add it to the QuoteOpr and do the regen after hours.
Exactly, that’s why I didn’t clock in that it was actually QuoteOpr when you mentioned JobOper binding. David’s post sounded correct too but you specified JobOper binding, so I thought there were maybe two different bindings. Not sure why they named it that way.
