plop this in initialize custom code or form load
resourceGroupComboC1.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
when you say it let you type something in before, did you mean in the combo, or do you have a textbox still visible?
In the combo. No text box visible. I will put it back in, close out Epicor, and try again.
Alright, The retriever is for Resource Groups. That way all they need to do is select the resource group instead of typing; trying to eliminate human errors. Anyway, I typed in Greener, which is not a resource group and it still allowed me to save Greener.
It shouldn’t let you type anything at all.
You might have to use an epicombo or epiultracombo
Can post the whole code block @Will79 ? I’m betting there is something you are missing that you don’t know you’re missing.
// Custom code for UD24Form
// Created: 11/29/2022 7:03:57 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// Begin Custom Code Disposal
// End Custom Code Disposal
epiComboC1.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
//bool whatamI = resourceGroupComboC1.DropDownStyle;
You have your code in destroy custom code, it needs to be in initialize custom code.
And for christ sake! Please rename your custom controls…
lol, I think that’s his test one
umm…i feel a lot
It is! I rename them when I go into production. If its something I haven’t’ done before I do it in test till I learn, then do it again into live and rename accordingly. the resistance and the duplicating of steps helps me learn a bit.
ok, well as long as you don’t leave it that way.
Last question, and THANK YOU and @klincecum for assisting/teaching me along the way. I want to learn about the BAQCombo. I know it is in help but didn’t know if there is a better article I could review?
As many of us know who have worked with Epicor for a while is that some of the features and tools we are provided are not documented well or at all. This article along with others I hope to add in the future will try to fill the gaps in the Epicor...
Reading time: 3 min read
There’s this post as well. You pretty much just drop in the combo box, and set the parameters like is show in this screen shot. There really isn’t much more to it.
Not sure it’s related, but here’s a screenshot of one that’s working for me [image]
Just thought of this, is it possible to take one of the key fields and turn it into an dropdown?
As long as it’s not key one I think you can. Just bind your drop down to one of the key fields instead of wherever else you had it bound to.
Perfect! Curiously, when you setup the UD table in menu maint, it shows the key fields, but it doesn’t let you delete the text box. Is there a way around this besides hiding it?
Epicor has the following logic in place, that if you use CodeTypeID = 'something' in your SearchFilter, it will automatically make it a DropDownList.
Just for the record.
That is slick! One question, If I was to use this, where would I put in the info to populate the drop down?
