Udateable dashboard 9.05
This is in a post process directive on the BAQ under the updateext.
/* Update Primary Bin */
for each ttResults.
Find First PlantWhse where PlantWhse.Company = Cur-Comp and PlantWhse.PartNum = ttCallContextBpmData.ShortChar01 and PlantWhse.WarehouseCode = 'MAINT'.
if avail PlantWhse then Do:
assign PlantWhse.PrimBin = ttCallContextBpmData.ShortChar02.
End.
End.
In a preprocess I carry the values I need through the callcontextbpmdata
Sent: Thursday, December 11, 2014 8:31 AM
Subject: RE: [Vantage] udateable dashboard 9.05
Rob, would you mind sharing the code you used? I've been frustrated by PlantWhse, too.
I have an updateable dashboard that adds new parts, I also want it to add a new warehouse with a primary bin (from existing ones). Anyone accomplish this?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Rob, Updatable Dashbords normally use the UpdateExt method of the Business Object so sticking a bit of code (BPM) on UpdateExt Post Processing should do it
Thanks!
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Wed, Dec 10, 2014 at 2:45 PM, Rob Bucek rbucek@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>I have an updateable dashboard that adds new parts, I also want it to add a new warehouse with a primary bin (from existing ones).  Anyone accomplish this?<br>
Rob Bucek
FAX: (715)284-4084
</div>
<div style="color:#fff;min-height:0;"></div>
That’s where I thought id have to go as PlantWhse wasn’t part of the Part dataset… I think I actually have to create a new record in that table. thanks!
Rob Bucek
FAX: (715)284-4084
Sent: Wednesday, December 10, 2014 2:07 PM
To: Vantage
Subject: Re: [Vantage] udateable dashboard 9.05
Thanks!
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
On Wed, Dec 10, 2014 at 2:45 PM, Rob Bucek rbucek@...<mailto:rbucek@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Rob Bucek
PH: (715) 284-5376 ext 311<tel:%28715%29%20284-5376%20ext%20311>
Mobile: (715)896-3119<tel:%28715%29896-3119>
FAX: (715)284-4084<tel:%28715%29284-4084>
[cid:1.234354861@...<mailto:cid%3A1.234354861@...>]<http://www.dsmfg.com/>
Ok, I got it all working now, I assumed I had to create the record but I forgot the BL creates those for me in the PlantWhse, and the PartWhse, so the record was already there for me to update via ABL code.
Rob Bucek
FAX: (715)284-4084
Sent: Wednesday, December 10, 2014 2:16 PM
To: 'vantage@yahoogroups.com'
Rob Bucek
FAX: (715)284-4084
To: Vantage
Thanks!
Jose C Gomez
Software Engineer
Rob Bucek
