I created a UD Column in Part Maintenance, but for some reason I can’t see it unless I’m in Developer Mode.
Does anyone know why this might be?
Did you make a customization to display it somewhere? If you did, did you apply the customization to the menu item?
I want the customization to display in Part Maintenance.
I believe I correctly applied the customization to the menu item.
Actually, it looks like I’m grabbing the wrong customization in Menu Maintenance. How to I get the “PartDeviceInfo” customization to show up in Menu Maintenance? Right now the only option is that “Part Display” base extension, which is the wrong one.
Are you single company or multi company in Epicor?
Is your PartDeviceInfo customization set to AllCompanies? I think they have to be now, to be able to see them in the dropdown in Menu Maintenance.
We have multiple companies. How do I change it to all companies?
I never saw a way to change it, so I just would re-save it with a new name, making sure I check the All Companies box. I’m not sure if you can just re-save with the same name, just overwriting it. Try that. If not, maybe export it out, delete it in Epicor, and import it back in?
EDIT: We are only a single company, so I don’t know what might be different in a multi-company environment.
If you do a save as, you can overwrite the old one. It’s a little finicky (sometimes it tries to stop you) but it can be done.
That worked! Thanks so much for your help!
Awesome! And a happy Figure-it-Out-Friday to you!
