Ultragrid - looping to hide columns
Ross & Steven,
Thanks for the code. Worked great!
Kevin Simon
Ross Hughes
Sent: Monday, August 16, 2010 1:52 PM
Subject: RE: [Vantage] Ultragrid - looping to hide columns
Hi Kevin,
Try this:
For Each column As UltraGridColumn In grid.DisplayLayout.Bands(0).Columns
column.Hidden = True
Next
Then turn back on as required.
Ross
Behalf Of
ksimon8fw
Sent: Monday, August 16, 2010 11:22 AM
Subject: [Vantage] Ultragrid - looping to hide columns
I have added an ultragrid to a form, and assigned it a datasource. However,
as a default, it shows all fields from the datasource. On this application,
there are only a few fields that I want to display, so I would like to loop
through all the columns, hide them, then go back and unhide the select few
for display.
Right now, I am having to add a line such as this:
epiGrd.DisplayLayout.Bands(0).Columns("Number02").Hidden = True
for each field I want to hide. I'd like to add some type of code that does
the following:
For Each ColumnName in .....
epiGrd.DisplayLayout.Bands(0).Columns(ColumnName).Hidden = True
next
then, I would go back and set the hidden attribute to false on the few I
want displayed.
Has anyone done anything like this?
Thanks.
Kevin Simon
I have added an ultragrid to a form, and assigned it a datasource. However, as a default, it shows all fields from the datasource. On this application, there are only a few fields that I want to display, so I would like to loop through all the columns, hide them, then go back and unhide the select few for display.
for each field I want to hide. I'd like to add some type of code that does the following:
next
then, I would go back and set the hidden attribute to false on the few I want displayed.
Thanks.
Kevin Simon
Hi Kevin,
Try this:
Next
Ross
ksimon8fw
for display.
the following:
next
want displayed.
Thanks.
Kevin Simon
Here is some code I have on one of my forms that does that:
for each item as UltraGridColumn in ugdEpiCustom2.Rows.Band.Columns
If item.datatype.ToString = "System.String" Then
item.Nullable = 2
End If
item.Hidden = True
Next
ugdEpiCustom2.Rows.Band.Columns("Key1").Hidden = False
ugdEpiCustom2.Rows.Band.Columns("Key2").Hidden = False
ugdEpiCustom2.Rows.Band.Columns("Character01").Hidden = False
ugdEpiCustom2.Rows.Band.Columns("Date01").Hidden = False
ugdEpiCustom2.Rows.Band.Columns("Checkbox01").Hidden = False
ugdEpiCustom2.Rows.Band.Columns("Key1").Header.Caption = "Customer"
ugdEpiCustom2.Rows.Band.Columns("Key2").Header.Caption = "State"
ugdEpiCustom2.Rows.Band.Columns("Character01").Header.Caption = "Tax Exempt
Number"
ugdEpiCustom2.Rows.Band.Columns("Date01").Header.Caption = "Expires On"
ugdEpiCustom2.Rows.Band.Columns("CheckBox01").Header.Caption = "Not Tax Exempt"
Â
The item.Nullable is for string columns. If you don't set it to 2, null values
can cause a problem for Vantage. After I hide all the columns, I unhide the
ones I want and then set the column headers.
Sent: Mon, August 16, 2010 12:21:33 PM
Â
following:
next
displayed.
Thanks.
Kevin Simon
