We've noticed the same problem in 8.03.405a; the client just quits
without warning before you can even do anything. Then it works on the
second try. It's happened on the server several times and Epicor
Support has yet to resolve the issue reported August 25. It hasn't
happened on our clients but very few people are testing 405a.
--- In vantage@yahoogroups.com, "Ken Long" <ken@...> wrote:
> I've been noticing more general Windows problems of that very
> description lately. It seems to be interactions between multiple
> programs. I can usually work around it by changing the order I load
> the programs. For instance, I can't start our old SBClient (Avante)
> if I have CoreFTP running first. Try loading the Vantage client
> first thing right after bootup. Might also check to see what might
> be autoloading on boot without your knowledge.
> Ken Long
> Lectrosonics, Inc.
> On 16 Sep 2008 at 14:30, charles06072006 wrote:
> > We have been using Version 8.03.405a for the last couple of
weeks.
> > Beginning yesterday we had 5 machines that were unable to start
> > Vantage. They are able to log on, the splash screen pops up and
then
> > the MFGSYS.EXE process ends. There are no error messages,
nothing in
> > the event logs or the server logs. I have used sysinternal's
process
> > monitor and compared the processes of a successful execution and
one
> > that is unsuccessful. This has been a lengthy process and has
not
> > revealed any secrets. The machines worked last Friday but failed
on
> > Monday. There is no indication of any updates, etc. that have
occured
> > on the machines since Friday.
> > Has anyone else had the same problem? Is so, what did you do to
> > resolve the issue. Any help would be greatly appreciated. I do
> > believe it would be a wasted effort to call support.
> > Charles Carden
> > IT Manager
> > Manitex, Inc.
