Undo a backflush labor record - E10 possible?
Thank you Rob and Miguel.. that worked!
Sent: Friday, May 27, 2016 11:44 AM
Subject: RE: [Vantage] undo a backflush labor record - E10 possible?
Don’t have E10, but you can recall the labor entry with Qty completed, then delete it.  That should return the material and labor.  Then update the job.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, May 27, 2016 11:21 AM
We tried but since it was backflushed it doesn’t appear you’re allowed to correct them there
Sent: Friday, May 27, 2016 11:15 AM
To: Vantage List <vantage@yahoogroups.com>
Subject: Re: [Vantage] undo a backflush labor record - E10 possible?
I am not sure what a backflush operation does since we do not use that, but could you just correct it thru job adjustments?
On Fri, May 27, 2016 at 2:12 PM, Jose Ortega jortega@... [vantage] <vantage@yahoogroups.com> wrote:
Is there a way to undo a backflush labor entry? Somebody accidently marked an operation as backflush when it was supposed to be time and qty and we want to correct it.  Looking for some options.
Sarah Vareschi â–ª Systems Manager
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 â–ª www.nypromold.com
D 978.368.4718 â–ª F 978.365.4548
This e-mail may contain information which is confidential or privileged. The information is intended to be for the use of the individual or entity named above.  If you are not the intended recipient, be aware that any disclosure, copying, distribution or use of the contents of this e-mail is prohibited.  In the event of any error in transmission, unauthorized recipients are requested to contact the sender immediately and not to disclose or make use of this information.  No employee or agent is authorized to conclude any binding agreement on behalf of NyproMold with another party by email without express written confirmation by NyproMold Offices.
P Please consider the environmental impact of printing this e-mail.
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
Â
<div>
  <p>
Â
</div>
<div style="color:rgb(255,255,255);min-height:0px;"></div>
Sarah Vareschi ▪ Systems ManagerÂ
Â
NyproMold, Inc.
144 Pleasant St, Clinton, MA 01510 ▪ www.nypromold.com Â
D 978.368.4718Â â–ª F 978.365.4548
Â
Â
Â
NyproMold Offices.
NyproMold, Inc.
Remove the labor on the op that follows the backflush op.
Correct the laborentrymethod & then re-enter (& enter) your labordtl's.
Backflush labor can't be edited because the result is only a labordtl record with no laborhead record that would enable time & expense editing.
Rob Brown
Versa Products
On Fri, May 27, 2016 at 2:20 PM, Jose Ortega jortega@... [vantage]
<div id="ygrps-yiv-1490216976ygrp-text">
  <p>
NyproMold, Inc.
</div>
<div class="ygrps-yiv-1490216976yQTDBase ygrps-yiv-1490216976yqt4441113165" id="ygrps-yiv-1490216976yqt74269"><div style="color:#fff;height:0;"></div></div>
Forgot to say you need to allow your backflush process to kick in after removing the 'next' op's labor.
Rob Brown
On Fri, May 27, 2016 at 3:03 PM, Robert Brown
Rob Brown
Versa Products
<div id="ygrps-yiv-1731493208ygrp-text">
  <p>
NyproMold, Inc.
</div>
<div class="ygrps-yiv-1731493208yQTDBase ygrps-yiv-1731493208yqt4441113165" id="ygrps-yiv-1731493208yqt74269"><div style="color:#fff;height:0;"></div></div>
Miguel A. Santillan
NyproMold, Inc.
Disclaimer
