UOM Conversion Error - PartBin Records already exist
I am getting the following when trying UOM conversion. There is 0 on hand.
Check you part bins. You could have +10 and -10 so you would have partbin records, even if you have 0 on hand.
Thanks Brandon. I had somehow switched sites so once I looked at your bins suggestion I could see the differences. UOM conversion now completed.
Cheers
Sorry to revive a dead post but how did you convert the UoM if it did have Bin transactions? From what I understand in this post, even if you have any stock transactions you have partbin records and hence cant do the Uom conversion process.
