I have a BAQ developed in classic that I am trying to use in a Kinetic dashboard. One of the update fields has an advanced column editor that uses another BAQ to fill a dropdown list. This all works in classic but when I create a Kinetic app, it appears to work and the dropdown list populates but when I try to update, I get an ID error on that field. There does not seem to be a way to edit anything about this dropdown list in Application Studio, it just seems to work to populate the list. I am assuming that the update fail is because it is using the description instead of the ID in the list. The edit are happening from the data grid.
Is there a way to edit how the list works in the current setup or I’m thinking I might need to remove the Adv Config Editor from the BAQ and setup the combo in application studio on it’s own.
Any thought on this scenario?
Ed
