Updatable Dashboard “Select All” Button
Hello team :slight_smile:
I have created an updatable BAQ and put it in a dashboard and it is all working.
I’ve shown the dashboard to my user and now asking me if I can add a Select All button.
There are some topics that I am trying to follow here, but it’s just not working.
Below are the things I have done
  1. Created an Updatable BAQ - making the JobHead_SchedLocked Updatable and query settings is Allow Multiple Row Update
  2. Added it in the dashboard, checking the Updatable checkbox in the Properties
  3. Have added a blank tracker View in the dashboard.
  4. Deployed it. Added in Menu as dashboard assembly.
  5. Added a customization. Added a button and followed the codes in here - Updatable Dashboard "Select All" Option?
But it does not do anything on my dashboard. Not sure what I am missing here. It seems like my button and my grid are not connected.
Any help will be greatly appreciated.
Can you copy/paste your code here ? That would help.
Here is my code
I don’t get any errors when I test code. But when I run the dashboard, do my filters and refresh, then Click the Select All button I added, it does not do anything…
I did my tracker view in the dashboard and the only thing I added in the UI customization is the button and the below codes. I click anywhere on my dashboard summary to get my ControlReference for myGrid.
Thanks!
// Custom code for MainController
// Created: 8/11/2023 9:42:41 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
public class Script
		// Begin Custom Code Disposal
		// End Custom Code Disposal
EpiUltraGrid myGrid
        get
            return (EpiUltraGrid)
                csm.GetNativeControlReference("883ff389-683c-4faa-b8c9-783d696abb0d");
private void btnSelectAll_Click(object sender, System.EventArgs args)
        int cnt = myGrid.Rows.Count;
        string msg = string.Format("There are '{0}' rows in the grid.  Are you really realy REALLY sure you want to select ALL '{0}' rows?  Click Yes to confrim, No to cancel", cnt);
        if (MessageBox.Show(msg, "Select all the jobs", MessageBoxButtons.YesNo, MessageBoxIcon.Information) == DialogResult.Yes)
            ChangeAll(myGrid.Rows, true);
 public void ChangeAll(RowsCollection row, bool val)
        foreach (UltraGridRow r in row)
            if (r.GetType() == typeof(UltraGridGroupByRow))
                ChangeAll(((UltraGridGroupByRow)r).Rows, val);
            else
                r.Cells["JobHead_SchedLocked"].Value = val;
You don’t have anything in “Initialize custom code” which leads me to believe that you just copied the functions from below. Those don’t fire unless something calls them, and since you didn’t initialize and subscriptions nothing is calling them.
For button clicks, use the wizard to add the button click function, then put the code from btnSelectAll_Click into the function that epicor makes for you. The wizard will add what you need for the button click to work.
Thank you so much! That worked!
Good Afternoon attempting to get this running for frim release any way you could share your working code?
Hi
This is my working code now. Just make sure you add the btnSelectAll_Click in the Event Wizard cause that is what I’m missing before. Thanks!
using System;
using System.Data;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
		this.btnSelectAll.Click += new System.EventHandler(this.btnSelectAll_Click);
		this.btnSelectAll.Click -= new System.EventHandler(this.btnSelectAll_Click);
EpiUltraGrid myGrid
        get
        string msg = string.Format("There are '{0}' jobs that you are about to lock.  Are you sure you want to lock ALL '{0}' jobs?  Click Yes to confirm, No to cancel", cnt);
            else
