Updatable Dashboard with a UBAQ Method Directive Update Fails to Save
I have created an updatable BAQ for our Supply/Chain team which includes a dozen or so updatable fields in Part, PartPlant and PartWhse. This was then applied to a dashboard so it could be placed on the menu. During testing I noted that if any one of the dozen updatable fields has an error, the entire row turns red. I also found that a tooltip is used to state the error, but this only applies to the first one it encounters. To get around this, I created a UBAQ Method Directive for Update (Pre-processing) which has this code:
string pubMsg = "";
var resultQuery = queryResultDataset.Results
  .Where(row => !string.IsNullOrEmpty(row.RowMod)
  && row.RowMod != "P");
foreach (var ttResult in resultQuery)
  var buyerChk = (from buyerRow in Db.PurAgent
    where buyerRow.BuyerID == ttResult.PartPlant_BuyerID
    select buyerRow).FirstOrDefault();
  if (buyerChk == null && buyerChk.BuyerID != "")
    pubMsg += "Invalid Buyer specified for Part " + ttResult.Part_PartNum + ".\r\n";
  var planChk = (from planRow in Db.Person
    where planRow.PersonID == ttResult.PartPlant_PersonID
    select planRow).FirstOrDefault();
  if (planChk == null && planChk.PersonID != "")
    pubMsg += "Invalid Planner specified for Part " + ttResult.Part_PartNum + ".\r\n";
  var abcChk = (from abcRow in Db.ABCCode
    where abcRow.ABCCode1 == ttResult.PartWhse_SystemAbc
    select abcRow).FirstOrDefault();
  if (abcChk == null && abcChk.ABCCode1 != "")
    pubMsg += "Invalid ABC Code specified for Part " + ttResult.Part_PartNum + ".\r\n";
if(pubMsg != "")
  this.PublishInfoMessage(pubMsg,Ice.Common.BusinessObjectMessageType.Warning,0,"","");
My problem is that updates do not occur when this method directive is enabled. Disabling the method directive allows updates to occur.
Any thoughts what I might be overlooking here?
Tony G.
Start commenting out stuff until it runs.
I don’t see anything at first glance. I assume you got no errors?
Could be failing silently. Might want to wrap it in a try catch, and publish the infomessage for the exception.
I usually put this kind code check post processing on getlist and put a comment into a calculated field with what is wrong so they know in advance and don’t try to update and in the update processing check that status is blank before processing.
I really wanted to use FieldValidate. According to the Ice Tools User Guide:
This method occurs before the proposed change to a field is committed. You can use this method to validate proposed changes. For example, you can prevent users from entering an incorrect value in a certain field such as non-existent state.
Unfortunately, my initial attempts failed to produce any result. In a perfect world, this would fire once the user hits tab, but I couldn’t even get a simple message to display.
Yeah it doesn’t work that way. All of this is server side.
Well, it looks like I got my “perfect world” solution, and it works great. Here’s what I did…
In the BAQ Designer, I went to Update > General Properties and clicked the “Advanced Column Editor Configuration” button at the bottom. For each field that I wanted to FieldValidate to know about, I checked “Raise Events”.
Once this was done, I went back to the Updatable BAQ Method Directive, and created a new BPM for FieldValidate with the following code:
string fieldDesc = "";
if(result == false)
  switch(fieldName)
    case "PartPlant_BuyerID":
      fieldDesc = "Buyer";
      break;
    case "PartPlant_PersonID":
      fieldDesc = "Planner";
      break;
    case "PartWhse_SystemAbc":
      fieldDesc = "ABC Code";
      break;
  if(fieldDesc != "")
    throw new BLException("Invalid " + fieldDesc + ". Please re-enter or use the drop-down to select an option.");
Now, whenever a user types an invalid value and hits TAB, they get a simple exception message, and the cursor remains in the field with the bad value, and the row does not turn red.
Fortunately, in my case I was able to create mini-BAQs for the Updatable Field Editor to use for the drop-down values and their descriptions. My Supply/Chain director even made me create one for ABC Code since they might someday create a fourth option. :grinning:
