Hi All,
So I am trying to use a BAQ Dataview to show “On Hand Locations” for materials. When the dataview is clicked, the warehouse and bin locations will update to match the dataview.
It has worked successfully on the issue material screen, but on the mass issue material screen whenever I click off of one line to update the next on the material list it triggers the Negative Stock Check method which errors out the mass issue screen and clears all the data.
Below is the current script and image of what it looks like.
// Custom code for MassIssueForm
// Created: 3/20/2024 8:59:52 AM
extern alias Erp_Contracts_BO_MassIssueToMfg;
extern alias Erp_Contracts_BO_IssueReturn;
extern alias Erp_Adapters_MassIssuetoMfg;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.Lib.Broadcast;
public class Script
BAQDataView onHandLocForIssuingBAQDV;
int RowNumBAQ;
int RowNumIssue;
EpiUltraGrid eugIssueMaterialGrid;
CreateOnHandLocForIssuingBAQDV();
eugIssueMaterialGrid = (EpiUltraGrid)csm.GetNativeControlReference("7908565c-cc3c-43d1-b85b-9921ad88fb89");
this.gridOnHandLoc.Click += new System.EventHandler(this.gridOnHandLoc_Click);
this.gridOnHandLoc.Click -= new System.EventHandler(this.gridOnHandLoc_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
public void CreateOnHandLocForIssuingBAQDV()
onHandLocForIssuingBAQDV = new BAQDataView("OnHandLocForIssuing");
oTrans.Add("OnHandLocForIssuingBAQDV",onHandLocForIssuingBAQDV);
string pub1Binding = "Mtl.PartNum";
IPublisher pub1 = oTrans.GetPublisher(pub1Binding);
if(pub1==null)
string pubName = Guid.NewGuid().ToString();
oTrans.PublishColumnChange(pub1Binding, pubName);
if(pub1 !=null)
onHandLocForIssuingBAQDV.SubscribeToPublisher(pub1.PublishName, "Part_PartNum");
//When BAQ dataview is selected, update the warehouse and bin if not null
private void gridOnHandLoc_Click(object sender, System.EventArgs args)
//MessageBox.Show ("In Cell Activate");
RowNumBAQ = -1;
RowNumIssue = -1;
//Loop for active line in BAQ grid
foreach(var rowBAQ in gridOnHandLoc.Rows)
//MessageBox.Show ("In For Loop");
RowNumBAQ = RowNumBAQ+1;
if(rowBAQ.Selected == true)
//Loop for active line in Issuing Grid
foreach(var rowIssue in eugIssueMaterialGrid.Rows)
RowNumIssue = RowNumIssue+1;
if(rowIssue.Selected == true)
//MessageBox.Show ("In Selected IF");
if(gridOnHandLoc.Rows[RowNumBAQ].Cells["PartBin_WarehouseCode"].Value !=null && gridOnHandLoc.Rows[RowNumBAQ].Cells["PartBin_BinNum"].Value !=null)
//MessageBox.Show ("In Value Change Area");
eugIssueMaterialGrid.Rows[RowNumIssue].Cells["Warehouse"].Value = gridOnHandLoc.Rows[RowNumBAQ].Cells["PartBin_WarehouseCode"].Value.ToString();
eugIssueMaterialGrid.Rows[RowNumIssue].Cells["BinNum"].Value = gridOnHandLoc.Rows[RowNumBAQ].Cells["PartBin_BinNum"].Value.ToString();
