ttExist no rowmod flag.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Jun 7, 2012 at 7:21 PM, <effgroups@...> wrote:
> Does the tt tables still exist? And is their rowmod still flagged?
> I tried that a while back and if I remember correctly It didn't work. I
> will try again.
> We are on 90407A
> Ephraim Feldman
> -----Original Message-----
> From: Jose Gomez <jose@...>
> Sender: vantage@yahoogroups.com
> Date: Thu, 7 Jun 2012 09:34:37
> To: <vantage@yahoogroups.com>
> Reply-To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Updating OrderDtl records When change in OrderHed
> with BPM
> No you should be able to for each the ttorderhed table
> On Jun 6, 2012 10:38 PM, <effgroups@...> wrote:
> > But I still need to update the BPMdata to have the ordernum.
> > Ephraim Feldman
> > Date: Wed, 6 Jun 2012 22:32:18
> > with BPM
> > No bit you do your value changed check in pre if true enable post proc
> > then
> > you don't check again.
> > On Jun 6, 2012 8:19 PM, <effgroups@...> wrote:
> > > The reason is that I need then to setup 2 directives. One pre to
> enable
> > > the post and to set the order number in the BPMdata so I can do the
> post
> > > process.
> > > Or is there a way in the postprcess to check if a value was changed?
> And
> > > how to get the order number?
> > > Ephraim Feldman
> > > Date: Wed, 6 Jun 2012 19:05:11
> OrderHed
> > > with BPM
> > > Why does post processing bother you? It should do exactly what you
> want
> > > On Jun 6, 2012 11:49 AM, "Ephraim Feldman" <effgroups@...>
> wrote:
> > > > Hi All
> > > > I searched the message archive and didnt find a satisfying answer to
> > > this.
> > > > I think its a very simple need to be able to update UD fields in the
> > Dtl
> > > > when the Hed changes but when you do that with a Preprocessing BPM
> you
> > > get
> > > > a error record has been updated.
> > > > There has to be a simple way to do this without having to do a
> > > > post-processing
> > > > Im sure some of you have this issue
> > > > Thanks
> > > > Ephraim
> > > > [Non-text portions of this message have been removed]
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> have
> and
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
